Nuki Card with Callback support (supports both Lock & Opener, it replaces the official integration)
I have one so I might for the sake of following your learning curve experiment with it. If I get anything setup, I’ll share it here. But you’re right, ideally the native integration would pick this stuff up.
From a configuration perspective, it’s easier to just ask the user to configure all user-parameters in secrets (they are secrets) and then I pull them up as sensors when users pastes all the code in the sensor file. If I used input_texts there would be additional user steps to follow, that’s all. So, either I ask to put everything as input_text or as secrets, I didn’t like mixing things, the instructions are already too complex for my taste.
If you don’t like the sensors being recorded, you can filter it out.
Feel free to adapt it to your needs if you prefer input_text. The code is there to be changed/adapted by anybody. :slight_smile:
Sury, but that can also be done with input_text and not just with sensors :wink:
The beauty of HA is that you can solve the same problem in 100 ways, I chose one, and I explained why. I could argue that putting my sensitive information in input_text is not something that I like, but it’s subjective. :wink:
Like I said, input_text would require extra configuration steps, and I preferred to minimize those.
I’ll be more than glad, once it’s working, to add the opener bit to the integration. Let’s make sure that someone else with the opener can test it, obviously. :slight_smile:
Thanks a lot.
I went the easy way and simply used your callback idea to force an update of the Nuki integration itself. That includes the opener then, but it lacks all the wonderful attributes that you pull from the bridge.
Setup is fairly easy and I created a blueprint for that:
Yeah, the easy way still requires the Nuki official integration. My goal was different. But it’s good to have choices. :slight_smile:
It’s a nice feeling being able to click “ignore” while still having a fully working integration, that provides all info about the Nuki, and faster status feedback. :slight_smile:
Great work! This method is so much faster then just using the rest api.
Is it possible to get the lock_state on callback? The current binary sensor only updates when a door status change is triggered.
I’m trying to create a binary sensor, which is on when the lock is unlatching or unlocking (7 or 2) but can’t get it working.
Thank you, glad you liked it.
It’s already like that. Lock state and Door state are separate and update independently, each time a callback is received.
If it doesn’t work for you, make sure you configured everything correctly.
If you look at the code of the trigger sensor you should be able to understand how to do it. Take into account that the way I implemented it is a special case: it is a device_class door binary sensor and it is a sensor that is updated BOTH via callbacks from the bridge and polling via REST sensors.
You can create a simpler template trigger binary sensor, that is updated only by callback, and when called, you check the lock state (2 or 7) to turn it on/off. Or you could use this integration: The Lock state is represented by this attribute of the binary door sensor: state_attr('binary_sensor.nuki_door_state', 'lock_state'). If you check the code of the lock sensor, you will see that its state is retrieved by that attribute.
Thanks for the help! Yes I’ve seen the attribute, but for me it only updates from locked to unlocked (and vice versa).
It never reaches unlocking/unlatching (2/7). I’ve looked at the callback content and it seems like Nuki doesn’t send one on lock state change to 2/7, but rather it goes directly to 1 or 3. Seems like my use-case doesn’t work with the current callback logic.
I think the callback is done only on 1/3, check this log from the bridge: at 32:27 I do the unlock, at 32:31 the lock is completed, at 32:37 the callback is done. That means the callback is done only at the end of the action, so you will never receive the status changes you were looking for.
When you say paste the code above in the file templates.yaml, do i need to create such a file in the config directory? How do i reference it then in configuration.yaml?
You are right, I took for granted that every user knows how to better organize the config.yaml file when it becomes too complex, I’ll show you the end of my config.yaml, so you can understand what I mean in the instructions. Let me know if it’s clear.
automation: !include automations.yaml
climate: !include climate.yaml
group: !include groups.yaml
http: !include http.yaml
influxdb: !include influxdb.yaml
input_boolean: !include input_booleans.yaml
light: !include lights.yaml
lock: !include locks.yaml
logger: !include logger.yaml
panel_custom: !include panel_custom.yaml
rest_command: !include rest_commands.yaml
scene: !include scenes.yaml
sensor: !include sensors.yaml
script: !include scripts.yaml
switch: !include switches.yaml
template: !include templates.yaml
utility_meter: !include utility_meter.yaml
weather: !include weather.yaml
zha: !include zha.yaml
if i add this line (template: !include templates.yaml) i get this error, if i remove it all is good
Error loading /config/configuration.yaml: ‘utf-8’ codec can’t decode byte 0x91 in position 1210: invalid start byte
what do you have at line 1210? You probably have strange characters in config.yaml. Type it instead of copy&pasting the line. HA is telling you that there’s an illegal character in that position.
i figured it out, it ws the n´ in lock n´ go, it was written in ansi encoding and when i switched it to utf 8 , questionamarks appeared so i had to retype it.
Go figure
Maybe I’ll edit it to show a simple ' character.
DONE: renamed it to (lock 'n' go)
So everything is working as expected i can lock and unlock and get all the info, but the binary sensor does not get the updates via the webhook i guess.
I see this error in the logs
Logger: homeassistant.components.template
Source: components/webhook/__init__.py:36
Integration: Template (documentation, issues)
First occurred: 2:01:30 PM (1 occurrences)
Last logged: 2:01:30 PM
Error setting up trigger
  File "/usr/src/homeassistant/homeassistant/components/webhook/trigger.py", line 40, in async_attach_trigger
    hass.components.webhook.async_register(
  File "/usr/src/homeassistant/homeassistant/components/webhook/__init__.py", line 36, in async_register
    raise ValueError("Handler is already defined!")
ValueError: Handler is already defined!
EDIT: At some point there was an update done and it showed the status right, but this is not instant
Hello !
I “replaced” the old configuration (like v2) with this new one (I did it yesterday, so the latest version)
everything works, but from time to time, I have these errors (and all the sensors no longer work)
did I do something wrong? what can i check?
thank you very much ^^
