Nuki SmartLock is found after every restart (2021.3.3)
Hello all,
seems the new Nuki Smart Lock integration (from ui) has a bug. Every restart of my docker container shows me, that new hardware is found. Nuki wants to be configured again and again and again! Last but not least it fails because it is already configured.
Best regards,
Charly
Same here. The notification can be ignored, but yes, this seems to be a bug.
In the meanwhile I got the problem fixed. I found some snippets in my configuration file. I needed to delete all the snippets and the integration. After a restart I added the integration again and it works now.
Best regards,
Charly
The discovery of a new device seems to be triggered, if the Nuki configuration isn’t removed from configuration.yaml after migration. Deleting the manual configuration from configuration.yaml solved the issue. No need to delete and re-add the already migrated Nuki device in the UI.
