Heya all! I’m trying to use BT proxies on ESPHome to measure distances, im having trouble keeping all me ESP32’s connected at the same time, I have found some mention that there can only be 3 connections at the same time. Is this actually the case? I have only found mention of it once… If it is true, how can I increase this?
@jackjourneyman@nickrout
Thanks for the info! feeling so swamped in this project im sure im missing things all over…
So the default is 320ms?
@nickrout truth be told, no, I was just despratly trying to find somthing that worked as a starter and figured I would fine tune from there. Missed the part about the default value being best and just got copied over. Worked well enough, but I wouldnt be surprised if its a large part of my problem…
Going back to your original post, the beta version of Bermuda (0.6.9rc2) might be better for your purposes as it allows you to fine tune by applying an offset to each individual proxy.
My experience has been that a room’s layout can sometimes have quite a dramatic effect, making the proxies seem further away from the device they’re tracking. If you have rooms on several floors the results can also be a bit odd.
