Then trigger from a state change to the sensor as I suggested above.
Not out of the wood yest and no central heating this morning, it was 14C in the house.
Iāve now discovered the log info and trace info given on the lovelace front end viewed on a Falkon web browser , misses a lot of info, whereas the companion app , android, shows much
The trace on the companion app showed this:-
Executed 25March 2024 at 08:00:00
Error in ānumeric_stateā. In ānumeric_stateā condition: entity sensor.tv_control_temp_sensors_temperature stateā can not be process as a number
The same message then repeated as entity_id/0
alias: Central Heating Morning
description: ""
- platform: time
at: "08:00:00"
condition:
- condition: state
entity_id: input_boolean.notify_away
state: "off"
- condition: numeric_state
entity_id: sensor.tv_control_temp_sensors_temperature
value_template: ""
below: 16
- type: turn_on
device_id: 0b6e278afd061db57c5ac8961518b0a9
entity_id: b694f2bce0f086bce79b6505f2540bfd
domain: switch
mode: single
Iāve used the Shelly temperature sensor withe the Shelly 1+ PM throughout and the temperature is displayed on the lovelace gauges and graphs.
Checking the config in developer tools shows no error
What doesnāt it like with the condition using a numeric state ???, as I used numeric state conditions to cover the numeric threshold misses
Your value_template: ""
line says āignore the actual value and replace it with an empty stringā. Thatās why youāre getting that error. Why did you add that line?
