Numeric state trigger above/below helper value
I want the trigger below to compare with a helper value:
input_number.threshold_overproduction_warning
instead of a fixed value 0.5
  - platform: numeric_state
    entity_id: sensor.totaal_generatie
    above: 0.5
You can’t use templates or entity_ids for that field, you’d need to replace it with a template trigger.
    value_template: "{{ states('sensor.totaal_generatie')|float > states('input_number.threshold_overproduction_warning')|float }}"
That got accepted so seems to work :slight_smile:
thanks for the help
