NUT Sensor - input.voltage not showing
Recently noticed that some of the parameters returned by the NUT sensor are missing, for example input.voltage … does anyone have the same problem? I am not sure if this occured after the an HA update. I am getting only the following info
pi@raspberrypi:~ $ upsc modem_ups@localhost
Init SSL without certificate database
battery.charge: 100
battery.charge.low: 10
battery.charge.warning: 20
battery.mfr.date: CPS
battery.runtime: 3600
battery.runtime.low: 300
battery.type: PbAcid
battery.voltage: 13.2
battery.voltage.nominal: 12
device.mfr: CPS
device.model: Value600ELCDGP
device.type: ups
driver.name: usbhid-ups
driver.parameter.pollfreq: 30
driver.parameter.pollinterval: 2
driver.parameter.port: auto
driver.parameter.synchronous: no
driver.version: 2.7.4
driver.version.data: CyberPower HID 0.4
driver.version.internal: 0.41
ups.mfr: CPS
ups.model: Value600ELCDGP
ups.productid: 0501
ups.status: OL
ups.vendorid: 0764
pi@raspberrypi:~ $
reboot of the UPS solved the issue
