I recently switched from a Fire Stick to Nvidia Shield Pro. So far I’m really happy with the Shield but I’m struggling with the Home Assistant integration. I’ve tried using the same Android Debug Bridge integration that I’ve used for the fire stick but I’m running into two problems:
- The source app is often listed as “Failed to write while dumping service window: Broken pipe”
- I keep seeing a status of Playing when the Shield is in a menu (either the app or the main menu).
I also tried the Google Cast integration which is great when it’s working, but then it will not update for long periods of time.
Has anyone found a good way to get play/pause/idle states from the Shield?
