Observer container appears to be up, HA container does not
hi, just flashed fresh on a CM4 and port 8123 for the HA interface itself just won't come up. as far as I can tell the container won't start including after reboots. I'm working on a Turing Pi 2 and while the CM4 is plugged into Node 1 and I can see video, I cannot seem to get my keyboard to work with Node 1 at all so I can't even use the console, and of course SSH is turned off for whatever reason.
is there another image with SSH turned on by default?
And by that do you mean you can see/follow HA’s bootup sequence ?
Anyhow, i assume it’s not support for Turing Pi 2, you request, so did you plugg your keyboard into the CM4, or it’s a specific module for Turing Pi 2, without usb2 ?
PS: Try Node 3 or 4, as i think you have no use for the “Video” which 1-2 provide
the problem is that USB is silently disabled on CM4s out of the box. you have to edit config.txt in the boot partition to fix this.
