Titles says it all. Occasionally the garage door is physically open but the state recorded in the UI implies it is shut. I can see the sensor reporting open. Any ideas? I’m using the ecolink tilt sensor and the zooz16 multichannel relay to trigger the motor.
cover:
covers:
garage_door1:
friendly_name: "Garage Door 1"
entity_id: binary_sensor.bay1_tilt_access_control_window_door_is_open
value_template: "{{ is_state('binary_sensor.bay1_tilt_access_control_window_door_is_open', 'on') }}"
device_class: garage
open_cover:
service: switch.toggle
entity_id: switch.multirelay_channel1
close_cover:
stop_cover:
garage_door2:
friendly_name: "Garage Door 2"
entity_id: binary_sensor.bay2_tilt_access_control_window_door_is_open
value_template: "{{ is_state('binary_sensor.bay2_tilt_access_control_window_door_is_open', 'on') }}"
open_cover:
entity_id: switch.multirelay_channel2
close_cover:
stop_cover:
garage_door3:
friendly_name: "Garage Door3"
entity_id: binary_sensor.bay3_tilt_access_control_window_door_is_open
value_template: "{{ is_state('binary_sensor.bay3_tilt_access_control_window_door_is_open', 'on') }}"
open_cover:
entity_id: switch.multirelay_channel3
close_cover:
stop_cover:
