Hi there,
I can´t quite get the hass.io addon occu to work…
I´m using HM-MOD-RPI-PCB that is capable of bidcos-rf and hmIP (/dev/ttyAMA0).
Therefore my config looks as follows:
"rf_enable": true,
"rf": [
"type": "CCU2",
"device": "/dev/ttyAMA0"
"wired_enable": false,
"wired": [
"serial": "xy",
"key": "abc",
"ip": "192.168.0.0"
"hmip_enable": true,
"hmip": [
"type": "HMIP_CCU2",
But this won´t work resulting in the following error:
[ERROR] Error while trying to open serial port: Exception while trying to open serial port. Check configured port ‘/dev/ttyAMA0’ [INFO] Exiting update tool.
If I set hmIP_enable to false so that only “rf” is using /dev/ttyAMA0 everythign works and the service starts normally…but of course without hmIP Support.
Can you help ?
Is there really noone out there who can help me ?
Got answer from the dev:
opened 10:56PM - 07 Jan 19 UTC
closed 12:34PM - 23 Apr 19 UTC
wontfix
… Therefore my config looks as follows:
"rf_enable": true,
"rf": [
"type": "CCU2",
"wired": [
"serial": "xy",
"key": "abc",
"ip": "192.168.0.0"
"hmip": [
Log:
Blockquote
Yes, we don’t support HmIP with HM-MOD-RPI-PCB because we don’t want to integrate the kernel hack for this device.
Use the USB adapter for HmIP.
Blockquote
