Short version: Where can I specify the port or URL for a webcam in the OctoPrint integration?
More infoL I have a Pi running 2 instances of OctoPrint so I can control 2 printers through it. Home Assistant sees both instances. I don’t use the regular port numbers for the 2 instances of OctoPrint or the 2 webcams (one for each printer).
I see no place where I can specify the port number or path or URL for a webcam, so, apparently, the integration just assumes the webcam is always at the same port.
I’ve asked about where the config file might be for this integration a good while ago and never received an answer. I’ve asked on GitHub about this without a clear answer. If I could add the webcam streams to this integration, it’d help me with several things I’m planning.
