Octopus integration
Is anyone seeing isses with the Octopus Add on? Mine seems OK except for the Current Demand which has been stuck on 349W for the last day or so. The Octpous App is reading from the Octopus Mini OK and the other readings in HA all look OK, but for some reason current demand is not reading correctly. Obviously tried restarting, re installing, restarted OHM etc.
Working again now, maybe there was a lag of several minutes after resetting the OHM
