Odd behavior of statistics when summing up two sensors
Hi, I have two sensors providing peak and off-peak values
When I set them out in a statistics graph they exactly show as it is
However, if I add them up then statistics do (imo) odd things…does anyone maybe have an explanation?
Sensor 1
Sensor 2 looks the same only different kWh values
Individual stats graph
I created a sum of both
      - name: "Linky Energy Total"
        unique_id: Linky Energy Total
        device_class: energy
        unit_of_measurement: kWh
        state_class: total_increasing
        state: "{{ states('sensor.linky_bbrhcjb')|float(0) + states('sensor.linky_bbrhpjb')|float(0) }}"
        availability: "{{ is_number(states('sensor.linky_bbrhcjb')|float(0) + states('sensor.linky_bbrhpjb')|float(0)) }}"
and this looks like:
What it seems to do is to pick the meter value at points and then continues (as expected) with total increase and then jumps again…but not every day
Change this:
To this:
availability: "{{ states('sensor.linky_bbrhcjb')|is_number and states('sensor.linky_bbrhpjb')|is_number }}"
Or, preferably, this:
availability: "{{ has_value('sensor.linky_bbrhcjb') and has_value('sensor.linky_bbrhpjb') }}"
Thanks, will try this out a bit, additional info…the 2 jumps you see are at around13:00 and around 20:00 …and I restart HA ervy dat at 01:00 …without jumps…hence I find this odd, might it be that the entity gets disconnected from the meter?
Not sure, your template sensor should update whenever either of the source sensors (linky_bbrhcjb or linky_bbrhpjb) updates.
