Odd behavior with Wink Hub and devices
Running:
Latest HASS .65
Ubuntu 16.04 with venv running homeassistant
I have the Wink Hub 2 in which all of my lights, locks and sensors are connected to which they also works in my home-assistant. Everything works fine usually…if the server restarts the service starts it as normal but the wink hub shows up as…
Invalid Config
The following components could not be setup
  • wink
DISMISS
My SABnzbd sensor also shows up with the configure button as if its never been setup. To remedy this a simple restarting of the homeassistant.service file fix its everything and it all shows up again. Any ideas what is causing this? It seems like initial login/connect to Wink and also SABnzbd are failing but upon restarting of the server (not the server itself) resolves it.
Any ideas or maybe something I can try? It does this upon every restart that the server has. Could it be the venv that is causing this? I know little to nothing about virtual environment and venv so I am just guessing…
