Odd error with data_template value in list
Overall goal: I want a lamp that shows a different color throughout the week, based on the position of the current time within the span of that week. I have a integer range of 0-360 to represent that color, and so I’m trying to place an integer value (derived from adding minutes together and mapping to a value from within that range) into an hs_color list.
My automation looks like this:
- id: '1589554169867'
  alias: Update Multicolor Lamp
  description: Update color of multicolor lamp based on position in week
  - minutes: '*/28'
    platform: time_pattern
  condition: []
  - data_template:
      brightness_pct: 50
      hs_color:
      - '{{ (((now().weekday() * 1440) + (now().hour * 60) + (now().minute)) / 28) | int }}'
      - 100
    entity_id: light.multicolor_lamp
    service: lifx.set_state
This validates as valid YAML and passes the overall configuration check. But when I load it as an automation, I get this error:
  File "/usr/src/homeassistant/homeassistant/util/dt.py", line 235, in parse_time_expression
    res = list(sorted(int(x) for x in parameter))
ValueError: invalid literal for int() with base 10: '*'
I’ve tried every variant of quotes, not quotes, etc. If I remove the quotes around the template portion, I get this error from the overall configuration check:
Error loading /config/configuration.yaml: invalid key: "OrderedDict([('(((now().weekday() * 1440) + (now().hour * 60) + (now().minute)) / 28) | int', None)])"
  in "/config/automations.yaml", line 1182, column 0
I must be doing something stupid. Does anyone know what it is? Thanks.
minutes: '*/28' is invalid.
minutes: '/28' is what you’re looking for if you want it to trigger each time the minute is divisible by 28 (as in at minute 28 and 56 of each hour).
Thanks! That was it exactly. I was getting my crontab and time_patterns mixed up.
Ha, that’s exactly what I thought when I saw it.
‘*28’ will go every 28 minutes regardless of the position in the hour
So /28 will trigger at 0, 28 and 56 minutes past the hour (i.e. modulus of minute leaves 0 as remainder)
and …
*28 will go ‘every 28 minutes’ from some arbitrary starting point (no one has ever been able to define that for me !)
