I bought a Odriod MS1 to install home assistant on it but after flashing from the MS1 link it is unresponsive. I flashed from file the Odriod image to an SD card and plugged that into the MS1. I then powered it on and plugged it into my Computer and flashed the home assistant from the MS1 URL provided by the guide online the flash failed with a something went wrong message. I decided to see if the MS1 worked even with this error. I then removed the SD card and plugged it into an Ethernet Port and plugged it into a power outlet. I was unable to find the IP address in my Modem and WiFi router and using the link http://homeassistant.local:8123 did not pull up the welcome page. I plug the MS1 into a keyboard and monitor and nothing pulls up there. I have plugged it back in to my computer with the SD card in and it no longer shows up again to re flash the MS1 url. Is there anything I can do to recover it or is it probably bricked at this point.
