Odroid c4 doesn't startup using the SD card
Good evening, I am new to using Home Assistant, and unfortunately I am already blocked in the beginning of the installation process. I have created a flash SD card, using Etcher app. That seems to work fine. I am now putting SD card in the Odroid C4, connect utp with network and then power on. Apart from a few lights nothing happens (don’t see anything on several url’s ending :8123). To double check I have connected a monitor with HDMI, but what I can see is the Odroid seems to get stocked in the process of starting kernel.
Attached a picture of the screen.
Anyone who can help? Do I need to somehow give the odroid a fixed IP? And if so, how could I do that? I am using my modem in bridge mode, with several TP Link AP’s. I have connected the odroid with UTP to the main TP Link AP.
Hope someone has tips.
Thanks,
Aart
