ODROID-N2+ need direction setting up Insteon devices/path
I’m migrating away from Home Control Assistant that was loaded on a mini pc and connected to a 2413U PLM. I have purchased a ODROID-N2+ with Home Assistant pre-loaded. At this point in time I have HA up and running but need further help. I’m assuming that the cable from the 2413U now plugs into one of the USB ports on the rear of the ODROID is this correct? When I try to initially add Insteon it asks for a path and I’m unclear what to add here and hoping someone might offer assistance. Thanks!
