Just installed HA on an Odroid XU4 and everything went fine but once the system is up and running the cooling fan for the cpu constantly revs up every few seconds, and its driving me insane! I have found solutions on the web but they require the ability to edit certain files which isn’t possible with HA OS, has anyone run into the same problem or been able to correct it?
I know this is a few months old but it is the only google entry that matches this topic. I had the same problem on my hassio setup on a XU4. Go through your add-ons and enable them 1 at a time. Turns out my motion eye add-on was looking for an old ip camera that wasn’t on and was causing the fan to cycle up every couple of seconds. Hope that helps.
