I have a template with an if statement to check if my eq3 valve is closed and in manual mode. However, the preset_moded defaults to ‘none’ if I set it in my if statement to ‘off’. Any idea why?
hold_state_template: >-
{% if value_json.temp == 4.5 and value_json.mode == 'manual' %}
off # is set to none ?!
{% elif value_json.temp == 30 and value_json.mode == 'manual' %}
on
{% else %}
{{ value_json.mode }}
{% endif %}
complete config:
- name: TRV
modes: ["heat","off","auto"]
min_temp: 4.5
max_temp: 30
precision: 0.1
temp_step: 0.5
mode_command_topic: cmnd/tasmota_ble/EQ3/001A2216F844/mode
temperature_command_topic: cmnd/tasmota_ble/EQ3/001A2216F844/settemp
current_temperature_topic: stat/EQ3/001A2216F844
current_temperature_template: '{{ value_json.temp }}'
mode_state_topic: stat/EQ3/001A2216F844
mode_state_template: >-
{% if value_json.temp == 4.5 %}
off
{% elif value_json.hassmode == 'auto' %}
auto
{% else %}
heat
{% endif %}
hold_modes: ["auto","manual","off","on","boost","lock","unlock","day","night"]
hold_command_topic: cmnd/tasmota_ble/EQ3/001A2216F844
off
on
{% else %}
{% endif %}
hold_state_topic: stat/EQ3/001A2216F844
