Office 365 Integration for Home Assistant not working after update
Hello everyone
Last August I successfully installed the Office 365 Integration for Home Assistant to synchronize my calendar with HA according to these instructions GitHub - RogerSelwyn/O365-HomeAssistant: Office 365 integration for Home Assistant.
Yesterday I updated this repository as well as my HA environment and since then the calendar entries can no longer be updated.
I found out that the command: list_events is deprecated and I have to replace it with the command: get_events. I did that, unfortunately without success. I now see the following error message in my log:
Logger: homeassistant.components.automation.import_kalender_marc
Quelle: components/automation/init.py:687
Integration: Automatisierung (Dokumentation, Probleme)
Erstmals aufgetreten: 7. März 2024 um 14:30:00 (18 Vorkommnisse)
Zuletzt protokolliert: 04:30:00
Error while executing automation automation.import_kalender_marc: Service call requested response data but did not match any entities
My automation:
alias: Import Kalender Marc
description: ""
  - platform: time_pattern
    minutes: "30"
condition: []
  - service: calendar.get_events
      duration:
        hours: 72
        minutes: 0
        seconds: 0
    response_variable: scheduled_events
      entity_id: calendar.kalender_marc
  - event: marc_scheduled_events
    event_data:
      scheduled_events: "{{ scheduled_events }}"
mode: single
my configuration.yaml:
o365:
  accounts:
    - account_name: Marc # Do not use email address or spaces
      client_id: "<ID>"
      client_secret: "<SECRET>"
      alt_auth_method: False
      enable_update: true
      email_sensor:
        - name: inbox
          max_items: 2
          is_unread: True
          download_attachments: False
      query_sensors:
        - name: "Example"
          folder: "Inbox/Test_Inbox" #Default is Inbox
          subject_contains: "Example subject"
          has_attachment: True
          max_items: 2
          is_unread: True
      status_sensors: # Cannot be used for personal accounts
        - name: "User Teams Status"
      chat_sensors: # Cannot be used for personal accounts
        - name: "User Chat"
      todo_sensors:
        enabled: False
template:
  - trigger:
      - platform: event
        event_type:
        - marc_scheduled_events
      - name: Marc Scheduled Events
        unique_id: marc_scheduled_events
        state: "{{ trigger.event.data.scheduled_events.events | count() }}"
        attributes:
          scheduled_events: "{{ trigger.event.data.scheduled_events.events }}"
        icon: mdi:calendar
Can someone help me here?
Many thanks
Greetings
Buhli
I could fix it. The problem was all the sensors (mail, chat, status etc.) in the yaml file. I have not granted the necessary permissions for these sensors in Azure.
First: I had to adjust the yaml as follows:
o365:
  accounts:
      client_id: "<ID>"
      enable_update: true
Second: According to this site Authentication | O365 Home Assistant I followed the steps ‘MFA’ und ‘Re-authentication’
