I just did a clean install of Home Assistant and when I go to the Add-Ons section it doesn’t show anything and if I check the repo it shows unknown. I’ve tried deleting it and adding it again but it just keeps showing unknown. Anyone know why? I just tried refreshing the whole thing and the issue is still happening.
What add-on is it?
Maybe the add-on requires Advanced Mode? (Click on your Initial (bottom left in menu) and enable Advanced Mode then try again
It’s the default one that comes with Home Assistant. However, I did try that but still nothing. It just shows it as Unknown in the repo section.
Ok so I think somewhere in the setup something went wrong. I just got a new SD card and re did everything. Now everything seems to be there.
