Hello people o/ First, thanks for the amazing product and for all the support here. It definitely helps a lot.
The Problem: I am running HAOS on Proxmox and facing a strange issue where I cannot install any official add-ons from the store. However, installing add-ons from third-party GitHub repositories works perfectly fine. When I try to install an official add-on, it just hangs or fails.
Environment:
- OS: Home Assistant OS (HAOS) running on Proxmox
- Installation Method: Proxmox VE Helper Scripts (tteck)
- Network: Pi-hole with Unbound (DNS)
What I have tried so far:
- Reinstallation: I have completely reinstalled the VM a couple of times, but the issue persists.
- Updates: Updated HAOS and Core to the latest versions.
- DNS & Pi-hole: I verified HAOS DNS settings were correct. I also tried changing the DNS inside the containers manually and completely disabled Pi-hole to rule it out, but neither worked.
- MTU: I read about potential MTU issues with Proxmox/HAOS networking and applied the recommended MTU fix, but it didn’t solve the problem.
Has anyone experienced this specific split behavior where only official add-ons fail? Any pointers on what to check next would be appreciated. Thanks in advance ^^
