Oil Sensor
Having some issues validating this code, any ideas?
esphome:
  friendly_name: "oil-tank"
  area: Cottage
esp32:
  board: esp32dev
  framework:
    type: arduino
Enable logging
 logger:
Enable Home Assistant API
api:
  encryption:
    key: "AsiJx5ZDIPH5ADjXmF9y2VvXhcy/QALhntpgFODr3yw="
ota:
  - platform: esphome
    password: "192068ffe361577643055f4298f63657"
wifi:
  ssid: !secret wifi_ssid
mdns:
  disabled: False
captive_portal:
 # OPTIONAL WEBSERVER - USEFUL WHEN TESTING.
 web_server:
   port: 80
# this section defines how the sensor will work. Read on to see how I improved this.
 platform: ultrasonic
 trigger_pin: G15
 echo_pin: G16
 accuracy_decimals: 0
 update_interval: 10s
# battery powered version configuration - read more at ESPHome Deep sleep
deep_sleep:
  run_duration: 10s
  sleep_duration: 60min
Looks like your spacing is inconsistent, but that is not what the message is complaining about.
Looks like you missed putting the # to indicate a comment on two of your comments.
looks like there is space in front of logger:
That’s the next issue it would complain about.
Change it around a bit now, but still no joy…
esphome:
  area: Home
esp32:
  board: esp32dev
  framework:
    type: arduino
logger:
api:
  encryption:
ota:
  - platform: esphome
wifi:
captive_portal:
mdns:
  disabled: False
 web_server:
   port: 80
 trigger_pin: GPIO15
 echo_pin: GPIO16
 update_interval: 60s
 unit_of_measurement: "litre"
  filters:
  - lambda: return x * 1053;
  - sliding_window_moving_average:
    window_size: 20
    send_every: 10
  – calibrate_linear:#
  – 110 -> 0
  – 95 -> 204
  – 75 -> 544
  – 55 -> 900
  – 35 -> 1320
  – 15 -> 1660
  – 0 -> 1800
  run_duration: 10s
Yep. :sweat_smile:
it’s missing # in front of comment.
Also web_server has space in front
And sensor: options have indentations wrong…
and theese?
