OK, dust has settled down a bit, and here’s the current state of things:
- My Zigbee devices are all back, but with some caveats. All of these caveats are related to Xiaomi/Aqara devices.
Problem 1. My dual-rocker zigbee Aqara switches only expose Left Single, Right Single and Both Single actions. In the previous life )))), they exposed Hold actions for left, right and both. Did anyone run into a similar problem? What does it depend on? At the same time, my single round buttons all expose all imaginable actions (single/double/triple/quad/many/hold/release). My 6-button Aqara Opple switches (by far the best ever made imo) also expose all of their expected actions.
ignore this part, I think I know where the problem could be - I could’ve confused two Aqara switches that I have, one is v1 that only exposes 3 actions, the other is v2, that exposes much more. Will double-check.
Problem 2: one of my Sonoff Zigbee relays decided that it wants to join the network via the most remotely located Mi plug. As the result, the LQI is between 0 and 5 ))) And I can’t find the way to tell this stupid thing to connect to other coordinators that have much better link quality. In the Z2MQTT map this relay is connected to two nodes, one with great link and the other with this weak LQI. For some reason, the reported link quality is the worst one, and the behavior confirms it: sometimes it takes qiute a while to react to a switch command. Any ideas on how to fix it? Unpairing/repairing may help? Or is there a way to manually point the link?
- I am still stuck with my Mi Home integration. The logic escapes me.
- I can see ALL of my Mi Home devices in the Mi Home app on my Android: Mi DGNWG02LM Gateway (the one with an RGB LED Ring around it, Z2MQTT model lumi.gate.v3), four e27 Philips ZhiRui white bulbs, four E14 Philips ZhiRui Candle bulbs, and two Mi Smart Plugs (zigbee models). Of those I can see in my HA: the gate, two out of four e27 bulbs and both power sockets. I can’t see any of the e14 bulbs and for some weird reason two of the 4 e27 bulbs.
I double-checked the tokens via the Mi Home app, they all match what was there in the “previous life” (I know that because I have a light.yaml file with all IPs and tokens for bulbs).
And, of course, as we all know, I can’t re-authenticate my Mi Home account. The “advanced” way via the gateway IP and token does not work neither - it authenticates fine, but it does not add any of the missing devices into HA.
Any suggestions would be hightly appreciated! In fact, if I am able to revive my Mi Home devices, I’d be perfectly happy with the way my HA home is right now, I will manually re-do all the automations and do some further polishing of the dashboard, but the Mi Home bug is really a bummer…
Thank you in advance!
