Hello.
I have installed Home Assistant in a docker container (core: 2025.3.3, frontend: 20250306.0) and acquired a Home Assistant Voice (OK nabu), but I am not being able to configure It because I don’t see the “Discovered” section under “Configuration → Divices and services”, and I have not found any other way to add the device.
Is this device compatible with Home Assistant in docker container?
Regards.
Marcelo
