OKP life k2 Vacuum cleaner
Does anyone know if you could control the vacuum robot via home assistant?
there is an app though. I have no idea how to start now:
https://okplife.com/apps/
i reset the K2 robot from the own application and later I paired it with Tuna App.
i setup the cloud of tuna app here
and later on with the key generated I linked it on HA with the own integration
result is this one
immagine
@Destroyer1090 hey thanks for the answer. In the meanwhile I used the Local Tuya integration
See here my settings:
Works quite well
