Hi HA Community,
I am receiving a critical error in my instance LOG. I can only presume I installed this blueprint and removed it, however now filling my log with errors. I have looked into my config.yaml and there is nothing listed for it, however it persists.
Any thoughts on how to clean it up?
Thank you
Invalid config for [automation]: Failed to load blueprint: Unable to find markus78/simple-flashing-lights-via-on-off-and-delay-restore-previous-light-states.yaml (See /config/configuration.yaml, line 35).
File "/usr/src/homeassistant/homeassistant/components/blueprint/models.py", line 209, in _load_blueprint
blueprint_data = yaml.load_yaml(self.blueprint_folder / blueprint_path)
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 112, in load_yaml
with open(fname, encoding="utf-8") as conf_file:
FileNotFoundError: [Errno 2] No such file or directory: '/config/blueprints/automation/markus78/simple-flashing-lights-via-on-off-and-delay-restore-previous-light-states.yaml'
type or paste code here
