On splitting up the config
Hi
So I have two broadlink devices with a boatload of IR codes in them. This config is very verbose but stable, I don’t need to edit these files once I have the codes in there.
I tried to factor each broadlink device in it’s own switch YAML;
broadlink_downstairs.yaml and broadlink_upstairs.yaml and I include them into the configuration.yaml like so :
switch: !include broadlink_upstairs.yaml
switch: !include broadlink_downstairs.yaml
switch: !include switches.yaml
Both files look something like this:
- platform: broadlink
  host: 10.0.X.X
  mac: '34:EA:34:8D:XX:XX'
  type: rm_mini
  timeout: 15
  switches:
    fan:
      friendly_name: "Fan"
      command_on: 'JgDiASkPKg0Dikq6yygPKA8pDikqAA0FDioNKg0q'
      command_off: 'JgAEASkPKQ4NKg4qDSAAAA=='
    fanspeed2:'
    etc ...
However, that does not fly as I get this error in the log :
ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/configuration.yaml contains duplicate key “switch”. Check lines 158 and 161.
ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/configuration.yaml contains duplicate key “switch”. Check lines 161 and 162.
Is what I attempt possible or not? What can be done?
The why seems fairly obvious, you are only allowed one section named switch, and you have effectively created 3.
How to fix it as you want and have 3 seperate files I don’t know. Can you have nested includes? I don’t have the time to try iy now, and someone will probably chime in and say it doesn’t work, but something like:
switch: !include all_switch.yaml
Then in all_switch.yaml:
No idea if it will work, but worth a try.
You can only have one switch: declartion in your configuration.yaml file.
Use !include_dir_merge_list to add all your seperate switch files that you have put in a directory of your choosing:
Ah - that’s simple…
yep, include_dir_merge_list is the way to go if you want to split things that are list elements.
and in you need to split a file that contains an array (like input_boolean), use include_dir_merge_named.
Hi All,
I have a question im trying to split up my confg but keep getting errors
my configuration looks like this
homeassistant:
packages: !include_dir_named packages
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
This is fine, however if i try to add, sensors: !include sensors.yaml i get errors.
my understanding was i should really be able to use and name at all for example
test: !include test.yaml
Please Help
sensor: !include sensors.yaml
The bit before the first “:” (called the key, “sensor” in this case) must be something recognised by home assistant as a platform/integration or custom component.
So no. You cant use “test:”, or sensors: it must be sensor:
Hi @tom_l, thanks i obviously misunderstood. however i have entered this exactly as i typed it and im still setting errors.
this is how i have it
homeassistant:
i am using file editor to edit my yaml and doing this i cant even save and restart.
Apologies im very new to this.
Possibly needs a / after packages:
homeassistant:
  packages: !include_dir_named packages/
When you run the config validation tool what errors do you get?
Just in case:
To run the config check, go to your profile and enable Advanced Mode.
The tool should then be in the Configuration / Server Controls menu.
Hi Tom,
Im getting the following error.
Invalid config for [sensor]: required key not provided @ data[‘platform’]. Got None. (See ?, line ?).
for refference this is my config now
However if i use this
that works but my sensors dont work
in my config folder i have a folder called sensors, in that file i have different .yaml files for different sensors
im probably doing this all wrong.
thanks for your help
in your timedate.yaml, no sensor: is needed
# Time & Date
- platform: time_date
  display_options:
  - 'date_time'
still didn’t work, have moved everything back to the config.yaml
