On-the-fly Scene not restoring
Hello all,
I’m seeking some help because seemingly I’m going insane here.
I have an automation to “flash” a lightstrip red for 1s whenever the door opens.
The scene it calls is basically just a red color and on state for the ledstrip.
For some reason, just randomly on the 1st, 2nd, 3rd or 5th or 10th trigger, the automation just doesn’t work/restore the light to the previous state.
I’ve tried setting a delay after creating the scene, I’ve tried creating setting a delay before resetting, I’ve tried deleting the scene at the end of the automation, I feel like I’ve tried everything. This happens both when triggering manually and when triggering via sensor.
Here is my automation config:
alias: Office Door Opens
description: ""
  - platform: state
    entity_id:
      - binary_sensor.office3_office_door
    to: "on"
condition: []
  - service: scene.create
      scene_id: officebefore
      snapshot_entities:
        - light.yeelight_stripe_0x0000000005e303b9
  - delay:
      milliseconds: 50
  - service: scene.turn_on
    metadata: {}
      entity_id: scene.officedooropen
  - delay:
      hours: 0
      minutes: 0
      seconds: 1
      milliseconds: 0
      entity_id: scene.officebefore
    data: {}
  - delay:
      milliseconds: 250
  - service: scene.delete
    data: {}
mode: single
The most stripped down config I started with which also has this issue:
description: ""
  - platform: state
    entity_id:
    to: "on"
condition: []
      snapshot_entities:
    metadata: {}
  - delay:
      hours: 0
      minutes: 0
      seconds: 1
      milliseconds: 0
    data: {}
mode: single
Any idea what I’m doing wrong or what could be the issue?
What does the trace tell you?
Are there errors in your log?
Sadly, the traces are exactly identical whether the automation completes successfully or not. I’ve been staring at the traces for hours and comparing each and every one of them with all the little changes but they are all the same. In the eyes of HA the automation always completes successfully and has the same output…
And no errors in the logs at all.
Post the traces. :wink:
My guess would be, it’s not enough time. You fire the scene changes practically while the first scene is created. But just a guess!
I’d try it with a wait_template or a delay between the different scenes. wait_template seems the better way, but not tested.
As an experiment, replace scene.officedooropen with the actual command(s) to turn on the light and set its color to red. In other words, remove the scene “middleman” and allow the automation to control the light directly. See if it makes any difference.
Here are the traces for the automation as it is above:
worked
  "trace": {
    "last_step": "action/6",
    "run_id": "5bf689faa2229ad6e189ebd4a84fb1df",
    "state": "stopped",
    "script_execution": "finished",
    "timestamp": {
      "start": "2024-04-18T13:20:31.333276+00:00",
      "finish": "2024-04-18T13:20:32.678248+00:00"
    "domain": "automation",
    "item_id": "1713311337778",
    "trigger": null,
    "trace": {
      "trigger": [
          "path": "trigger",
          "timestamp": "2024-04-18T13:20:31.333346+00:00",
          "changed_variables": {
            "this": {
              "entity_id": "automation.office_door_opens",
              "state": "on",
              "attributes": {
                "id": "1713311337778",
                "last_triggered": "2024-04-18T13:19:35.312369+00:00",
                "mode": "single",
                "current": 0,
                "friendly_name": "Office Door Opens"
              "last_changed": "2024-04-18T12:13:12.728225+00:00",
              "last_reported": "2024-04-18T13:19:36.645246+00:00",
              "last_updated": "2024-04-18T13:19:36.645246+00:00",
              "context": {
                "id": "01HVRNSKWG3NE1Y4PVY8MDFV6X",
                "parent_id": "01HVRNSKWFP0C3G9XZRW81ZWQD",
                "user_id": null
            "trigger": {
              "platform": null
      "action/0": [
          "path": "action/0",
          "timestamp": "2024-04-18T13:20:31.333856+00:00",
            "context": {
              "id": "01HVRNVAK5T26JJ0PBHWY8ZCE1",
              "parent_id": "01HVRNVAK4K68998HSW9A9HE6Q",
              "user_id": null
          "result": {
            "params": {
              "domain": "scene",
              "service": "create",
              "service_data": {
                "scene_id": "officebefore",
                "snapshot_entities": [
                  "light.yeelight_stripe_0x0000000005e303b9"
              "target": {}
            "running_script": false
      "action/1": [
          "path": "action/1",
          "timestamp": "2024-04-18T13:20:31.334884+00:00",
          "result": {
            "delay": 0.05,
            "done": true
      "action/2": [
          "path": "action/2",
          "timestamp": "2024-04-18T13:20:31.386108+00:00",
          "result": {
            "params": {
              "domain": "scene",
              "service": "turn_on",
              "service_data": {},
              "target": {
                "entity_id": [
                  "scene.officedooropen"
      "action/3": [
          "path": "action/3",
          "timestamp": "2024-04-18T13:20:31.395020+00:00",
          "result": {
            "delay": 1,
            "done": true
      "action/4": [
          "path": "action/4",
          "timestamp": "2024-04-18T13:20:32.396255+00:00",
          "result": {
            "params": {
              "domain": "scene",
              "service_data": {},
              "target": {
                "entity_id": [
                  "scene.officebefore"
      "action/5": [
          "path": "action/5",
          "timestamp": "2024-04-18T13:20:32.423250+00:00",
          "result": {
            "delay": 0.25,
            "done": true
      "action/6": [
          "path": "action/6",
          "timestamp": "2024-04-18T13:20:32.675015+00:00",
          "result": {
            "params": {
              "domain": "scene",
              "service": "delete",
              "service_data": {},
              "target": {
                "entity_id": [
    "config": {
      "alias": "Office Door Opens",
      "description": "",
      "trigger": [
          "platform": "state",
          "entity_id": [
            "binary_sensor.office3_office_door"
          "from": "off",
          "to": "on"
      "condition": [],
      "action": [
          "service": "scene.create",
          "data": {
          "delay": {
            "milliseconds": 50
          "service": "scene.turn_on",
          "metadata": {},
          "target": {
            "entity_id": "scene.officedooropen"
          "delay": {
            "hours": 0,
            "minutes": 0,
            "seconds": 1,
            "milliseconds": 0
          "target": {
            "entity_id": "scene.officebefore"
          "data": {}
          "delay": {
            "milliseconds": 250
          "service": "scene.delete",
          "target": {
          "data": {}
      "mode": "single"
    "blueprint_inputs": null,
    "context": {
      "user_id": null
  "logbookEntries": [
      "name": "Office Door Opens",
      "message": "triggered",
      "source": null,
      "context_id": "01HVRNVAK5T26JJ0PBHWY8ZCE1",
      "when": 1713446431.333416,
      "when": 1713446431.386963,
      "state": "2024-04-18T13:20:31.386841+00:00",
      "entity_id": "scene.officedooropen",
      "icon": "mdi:office-building",
      "context_event_type": "automation_triggered",
      "context_domain": "automation",
      "context_name": "Office Door Opens",
      "context_message": "triggered",
      "context_entity_id": "automation.office_door_opens"
      "when": 1713446432.397079,
      "state": "2024-04-18T13:20:32.396990+00:00",
      "entity_id": "scene.officebefore",
failed
  "trace": {
    "run_id": "98da8eac5b9ee7be3fc767ea03671376",
    "state": "stopped",
    "timestamp": {
      "start": "2024-04-18T13:20:34.408869+00:00",
      "finish": "2024-04-18T13:20:35.730344+00:00"
    "trigger": null,
    "trace": {
      "trigger": [
          "path": "trigger",
          "timestamp": "2024-04-18T13:20:34.408966+00:00",
            "this": {
              "state": "on",
              "attributes": {
                "last_triggered": "2024-04-18T13:20:31.333421+00:00",
                "mode": "single",
                "current": 0,
              "last_reported": "2024-04-18T13:20:32.676300+00:00",
              "last_updated": "2024-04-18T13:20:32.676300+00:00",
              "context": {
                "user_id": null
            "trigger": {
              "platform": null
      "action/0": [
          "path": "action/0",
          "timestamp": "2024-04-18T13:20:34.409648+00:00",
            "context": {
              "id": "01HVRNVDK885ES4NBE9TMFDY5Y",
              "parent_id": "01HVRNVDK8VVT6KS8489AFXTKH",
              "user_id": null
          "result": {
            "params": {
              "domain": "scene",
              "service_data": {
              "target": {}
      "action/1": [
          "path": "action/1",
          "timestamp": "2024-04-18T13:20:34.411007+00:00",
          "result": {
            "delay": 0.05,
            "done": true
      "action/2": [
          "path": "action/2",
          "timestamp": "2024-04-18T13:20:34.462018+00:00",
          "result": {
            "params": {
              "domain": "scene",
              "service_data": {},
              "target": {
                "entity_id": [
      "action/3": [
          "path": "action/3",
          "timestamp": "2024-04-18T13:20:34.470479+00:00",
          "result": {
            "delay": 1,
            "done": true
      "action/4": [
          "path": "action/4",
          "timestamp": "2024-04-18T13:20:35.471782+00:00",
          "result": {
            "params": {
              "domain": "scene",
              "service_data": {},
              "target": {
                "entity_id": [
      "action/5": [
          "path": "action/5",
          "timestamp": "2024-04-18T13:20:35.475188+00:00",
          "result": {
            "delay": 0.25,
            "done": true
      "action/6": [
          "path": "action/6",
          "timestamp": "2024-04-18T13:20:35.726963+00:00",
          "result": {
            "params": {
              "domain": "scene",
              "service_data": {},
              "target": {
                "entity_id": [
    "config": {
      "description": "",
      "trigger": [
          "entity_id": [
          "from": "off",
          "to": "on"
      "condition": [],
      "action": [
          "data": {
          "delay": {
            "milliseconds": 50
          "metadata": {},
          "target": {
          "delay": {
            "hours": 0,
            "minutes": 0,
            "seconds": 1,
            "milliseconds": 0
          "target": {
          "data": {}
          "delay": {
            "milliseconds": 250
          "target": {
          "data": {}
      "mode": "single"
    "context": {
      "user_id": null
  "logbookEntries": [
      "source": null,
      "context_id": "01HVRNVDK885ES4NBE9TMFDY5Y",
      "when": 1713446434.4090624,
      "when": 1713446434.462896,
      "state": "2024-04-18T13:20:34.462801+00:00",
      "when": 1713446435.472832,
      "state": "2024-04-18T13:20:35.472713+00:00",
I tried this, by replacing the scene.officedooropen block with the following:
  - service: light.turn_on
    metadata: {}
      rgb_color:
        - 255
        - 0
        - 0
      brightness: 255
      entity_id: light.yeelight_stripe_0x0000000005e303b9
But sadly, it was the same issue.
Traces:
worked
  "trace": {
    "run_id": "fff0b80247307e6d16ff4636f2ec880b",
    "state": "stopped",
    "timestamp": {
      "start": "2024-04-18T13:39:08.460109+00:00",
      "finish": "2024-04-18T13:39:09.799253+00:00"
    "trigger": null,
    "trace": {
      "trigger": [
          "path": "trigger",
          "timestamp": "2024-04-18T13:39:08.460225+00:00",
            "this": {
              "state": "on",
              "attributes": {
                "last_triggered": "2024-04-18T13:31:39.268557+00:00",
                "mode": "single",
                "current": 0,
              "last_changed": "2024-04-18T13:31:23.023133+00:00",
              "last_reported": "2024-04-18T13:31:40.589705+00:00",
              "last_updated": "2024-04-18T13:31:40.589705+00:00",
              "context": {
                "id": "01HVRPFPW4TCXHHJFN31AHNCBP",
                "parent_id": "01HVRPFPW3C8DDQARWS6V4JV2E",
                "user_id": null
            "trigger": {
              "platform": null
      "action/0": [
          "path": "action/0",
          "timestamp": "2024-04-18T13:39:08.460972+00:00",
            "context": {
              "id": "01HVRPXDHCRANB1BD5RCEW71PP",
              "parent_id": "01HVRPXDHBAAXESDDW96NN3Y53",
              "user_id": null
          "result": {
            "params": {
              "domain": "scene",
              "service_data": {
              "target": {}
      "action/1": [
          "path": "action/1",
          "timestamp": "2024-04-18T13:39:08.462433+00:00",
          "result": {
            "delay": 0.05,
            "done": true
      "action/2": [
          "path": "action/2",
          "timestamp": "2024-04-18T13:39:08.513761+00:00",
          "result": {
            "params": {
              "domain": "light",
              "service_data": {
                "rgb_color": [
                  255,
                  0,
                  0
                "brightness": 255,
                "entity_id": [
              "target": {
                "entity_id": [
      "action/3": [
          "path": "action/3",
          "timestamp": "2024-04-18T13:39:08.529432+00:00",
          "result": {
            "delay": 1,
            "done": true
      "action/4": [
          "path": "action/4",
          "timestamp": "2024-04-18T13:39:09.530194+00:00",
          "result": {
            "params": {
              "domain": "scene",
              "service_data": {},
              "target": {
                "entity_id": [
      "action/5": [
          "path": "action/5",
          "timestamp": "2024-04-18T13:39:09.543542+00:00",
          "result": {
            "delay": 0.25,
            "done": true
      "action/6": [
          "path": "action/6",
          "timestamp": "2024-04-18T13:39:09.795433+00:00",
          "result": {
            "params": {
              "domain": "scene",
              "service_data": {},
              "target": {
                "entity_id": [
    "config": {
      "description": "",
      "trigger": [
          "entity_id": [
          "from": "off",
          "to": "on"
      "condition": [],
      "action": [
          "data": {
          "delay": {
            "milliseconds": 50
          "service": "light.turn_on",
          "metadata": {},
          "data": {
            "rgb_color": [
              255,
              0,
              0
            "brightness": 255
          "target": {
            "entity_id": "light.yeelight_stripe_0x0000000005e303b9"
          "delay": {
            "hours": 0,
            "minutes": 0,
            "seconds": 1,
            "milliseconds": 0
          "target": {
          "data": {}
          "delay": {
            "milliseconds": 250
          "target": {
          "data": {}
      "mode": "single"
    "context": {
      "user_id": null
  "logbookEntries": [
      "source": null,
      "context_id": "01HVRPXDHCRANB1BD5RCEW71PP",
      "when": 1713447548.4603255,
      "when": 1713447549.53109,
      "state": "2024-04-18T13:39:09.530997+00:00",
failed
  "trace": {
    "run_id": "9dbc755b8d72bd58cb7f209e48ec4a6d",
    "state": "stopped",
    "timestamp": {
      "start": "2024-04-18T13:39:11.318733+00:00",
      "finish": "2024-04-18T13:39:12.642790+00:00"
    "trigger": null,
    "trace": {
      "trigger": [
          "path": "trigger",
          "timestamp": "2024-04-18T13:39:11.318814+00:00",
            "this": {
              "state": "on",
              "attributes": {
                "last_triggered": "2024-04-18T13:39:08.460336+00:00",
                "mode": "single",
                "current": 0,
              "last_reported": "2024-04-18T13:39:09.796843+00:00",
              "last_updated": "2024-04-18T13:39:09.796843+00:00",
              "context": {
                "user_id": null
            "trigger": {
              "platform": null
      "action/0": [
          "path": "action/0",
          "timestamp": "2024-04-18T13:39:11.319376+00:00",
            "context": {
              "id": "01HVRPXGAPAAMCWEDH6HKA3SSD",
              "parent_id": "01HVRPXGAPH1ZK0MHGFR1933VZ",
              "user_id": null
          "result": {
            "params": {
              "domain": "scene",
              "service_data": {
              "target": {}
      "action/1": [
          "path": "action/1",
          "timestamp": "2024-04-18T13:39:11.321221+00:00",
          "result": {
            "delay": 0.05,
            "done": true
      "action/2": [
          "path": "action/2",
          "timestamp": "2024-04-18T13:39:11.372595+00:00",
          "result": {
            "params": {
              "domain": "light",
              "service_data": {
                "rgb_color": [
                  255,
                  0,
                  0
                "brightness": 255,
                "entity_id": [
              "target": {
                "entity_id": [
      "action/3": [
          "path": "action/3",
          "timestamp": "2024-04-18T13:39:11.382482+00:00",
          "result": {
            "delay": 1,
            "done": true
      "action/4": [
          "path": "action/4",
          "timestamp": "2024-04-18T13:39:12.383915+00:00",
          "result": {
            "params": {
              "domain": "scene",
              "service_data": {},
              "target": {
                "entity_id": [
      "action/5": [
          "path": "action/5",
          "timestamp": "2024-04-18T13:39:12.387801+00:00",
          "result": {
            "delay": 0.25,
            "done": true
      "action/6": [
          "path": "action/6",
          "timestamp": "2024-04-18T13:39:12.639701+00:00",
          "result": {
            "params": {
              "domain": "scene",
              "service_data": {},
              "target": {
                "entity_id": [
    "config": {
      "description": "",
      "trigger": [
          "entity_id": [
          "from": "off",
          "to": "on"
      "condition": [],
      "action": [
          "data": {
          "delay": {
            "milliseconds": 50
          "metadata": {},
          "data": {
            "rgb_color": [
              255,
              0,
              0
            "brightness": 255
          "target": {
          "delay": {
            "hours": 0,
            "minutes": 0,
            "seconds": 1,
            "milliseconds": 0
          "target": {
          "data": {}
          "delay": {
            "milliseconds": 250
          "target": {
          "data": {}
      "mode": "single"
    "context": {
      "user_id": null
  "logbookEntries": [
      "source": null,
      "context_id": "01HVRPXGAPAAMCWEDH6HKA3SSD",
      "when": 1713447551.318893,
      "when": 1713447552.385759,
      "state": "2024-04-18T13:39:12.385677+00:00",
Fixed it.
I’m now convinced this is due to the light itself and not the automation or home assistant - from what I remember yeelights are notorious for ratelimiting, especially when it comes to multiple requests in x timespan, or just straight away multiple commands.
As soon as I changed the delay from 1 second to 2 seconds, it stopped happening.
Based on that result, the next thing I was going to suggest is that it’s a problem with the device itself (specifically a communications timing issue) but you have already come to the same conclusion. Glad to hear you were able to mitigate the problem.
