onConnect event in Pyscript (Paho)
I have been trying for a few days to get a small MQTT Pyscript to work. Locally and through the console, the script works fine (connects, reads messages, etc.), but in the end, I want to set some Home Assistant input templates or template status.
For this reason, I put the code into a Pyscript file and set it as a service. When the service is run, I can see in the MQTT broker that it connects as it should. The input_number is set to 0 and 1. However, I cannot get it to work where a log output is created or an input_template is set to 2 in the onConnect method.
It seems like the entire onConnect (and following the onMessage, onDisconnect,…) method is not being called. There is no error in the log output. I have no idea where the issue could be. How can I, for example, create a log output or set the value?
I tried async/await as well, but it didn’t work either.
import paho.mqtt.client as mqttClient
import random
entityName = "input_number.statustester"
def connectLocalMQTT():
    def onLocalMQTTConnect(client, userdata, flags, rc):
        state.set(entityName, 2, attributes)
        if rc == 0:
            log.error("Connected to MQTT Broker!")
        else:
            log.error("Failed to connect, return code %d\n", rc)
    localMQTTClient = mqttClient.Client(LOCAL_MQTT_CLIENT+str(random.randint(0, 100)))
    localMQTTClient.username_pw_set(LOCAL_MQTT_USER, LOCAL_MQTT_PWD)
    localMQTTClient.on_connect = onLocalMQTTConnect
    localMQTTClient.connect(LOCAL_MQTT_HOST, LOCAL_MQTT_PORT)
@service
def mqttConnectTest():
    global attributes
    attributes = state.getattr(entityName)
    state.set(entityName, 0, attributes)
    state.set(entityName, 1, attributes)
    connectLocalMQTT()
I found a solution. @pyscript_compile has to be used for the callback functions. In the compiled functions there is no support of pyscript, so some changes are necessary.
(state.set → hass.states.set, logging).
Following the new source code:
import random
    @pyscript_compile
    def localMQTTOnConnect(localMQTTClient, userdata, flags, rc):
        entityOb   = hass.states.get(entityName)
        entityAttributes = entityOb.attributes.copy()
        hass.states.set(entityName, 2, entityAttributes)
        import logging
        if rc == 0:
            logging.error("Connected to MQTT Broker V2")
        else:
            logging.error("Failed to connect, return code %d\n", rc)
    localMQTTClient.username_pw_set(username= LOCAL_MQTT_USER, password= LOCAL_MQTT_PWD)
    localMQTTClient.on_connect = localMQTTOnConnect
    localMQTTClient.reconnect_delay_set(min_delay=1, max_delay=120)
    localMQTTClient.connect(LOCAL_MQTT_HOST,LOCAL_MQTT_PORT)
    localMQTTClient.loop_start()
@service
def testCompileInMqtt():
    global attributes
    connectLocalMQTT()
Everything works fine. Topic can be closed
