Onedrive - Cannot see option in Automation Action Location
Up until now I have used Automations to do my HA backups. I triggered a backup daily at 01:01hrs and save it to system disk. On Sunday I also triggered it at 03:00hrs to backup to my Synology NAS.
I have Now updated my HA to 2025.2.1 and before I setup the New Backup system I let my existing system run and it worked OK.
I then though I would do an off site backup using OneDrive as I have 1TB allocated to me.
I added the OneDrive Integration and it seems to load OK and I can see the Graph folder on my one drive.
My thinking was that I would duplicate the 03:00hrs automation and change the Day and location to OneDrive.
However I am not given that option:
I have blurred out the actual ip address on NAS
Can anyone tell me what I am doing wrong Please.
I wanted to test it this way before I setup the new system if possible and from what I have read it should be.
I think the new backup system only works with the action action: backup.create_automatic
That could be correct but the documentation does not seem to indicate that. One of the statements made was that you could use the automation system to do similar things to automatic.
I implemented the Automatic backups today and I can see the OneDrive Location in this so it means that this method of backup ( Create full backup from action) does not have access to OneDrive. Is this by design or a bug?
by design afaik
