Onkyo - Input Slider - Bi-directional
I spend ages trying to get a input slider (now input number) to work correctly. I could always control the Onkyo receiver (TX-NR414) but was struggling with automation to make the slider move if the volume was adjusted on the amp. Once I got it solved I though I would post this just in case someone else needs the code.
This is mostly copy/paste from various topics. If I log on to the web interface of my Onkyo it says the receiver is capable of 0-80 but currently set at 64 max, hence using 80 in the automations and 64 in the input_number.
I have not had time to test this, literally just got it to work but it definitely does work.
In configuration.yaml
input_number:
  onkyo_volume:
    initial: 15
    min: 0
    max: 64
    step: 1
Automations:
  - alias: Onkyo Volume Slider Set
      - platform: state
        entity_id: input_number.onkyo_volume
    condition:
      - condition: state
        entity_id: media_player.receiver
        state: 'on'
      - service: media_player.volume_set
        data_template:
          volume_level: '{{ states.input_number.onkyo_volume.state | float / 80 }}'
  - alias: Onkyo Volume Slider Get
      platform: state
      service: input_number.set_value
      data_template:
        value: '{{ states.media_player.receiver.attributes.volume_level | float * 80 }}'
Cheers
Simon
Hello simon,
I tried to replicate your sttings. Unfortunatly it doesn’t seems to work for my Google Home and Yamaha receiver.
Here is the automation code i used:
 - alias: google home - Adjust Volume
     - platform: state
       entity_id: input_number.slider1
       data_template:
         entity_id: media_player.google_home
         volume_level: '{{ states.input_number.google_home.state | float / 80 }}'
 - alias: yamaha - Adjust Volume
     - platform: state
       entity_id: input_number.slider2
       data_template:
         entity_id: media_player.home_cinema_main
         volume_level: '{{ states.input_number.home_cinema_main.state | float / 80 }}'
 - alias: google home - Volume
     - platform: state
     - service: input_number.select_value
       data_template:
         value: '{{ states.media_player.google_home.attributes.volume_level | float * 80 }}'
 - alias: yamaha - Volume
     - platform: state
       data_template:
         value: '{{ states.media_player.home_cinema_main.attributes.volume_level | float * 80 }}'
And there is my input_number:
input_number:
  slider1:
    initial: 40
    min: 0
    max: 100
    step: 10
  slider2:
    initial: 40
    min: 0
    max: 100
    step: 10
If you have any suggestions i will really appreciate.
Hello Simon,
Thanks for sharing this configuration info. It solved a nagging issue I’ve had with my setup that just became apparent since version 0.81.0.
Steve K.
Wow, i have been trying to get this to work correctly for a week (finally got it “working” with a 0 to 1 slider, but the numbers didnt match up since the python file limits it to 80 and mine goes to 100).
Thank you, now when my volume is 54, it says 54 not .6275
