Hi all, if I want to turn off all my lights in say the “basement” area and use the Service Light UI, I would just select the area “basement” and all lights are in the basement would turn off. However, in the Light Service UI only Areas show up that actually have devices in them. In my house, all almost my lights are KNX entities (not devices!) so the areas that only have light.xxx as KNX entities do not show up in the UI. I can add the areas directly in the YAML code just fine and then the UI also displays them nicely and I can e.g. remove them again, but it would of course be nice to have the ability to pick areas with light.xxx entities in them also directly in the UI. Btw, the same is true for scenes, scenes only accept devices, but my Light Scenes would all be entities since KNX lights are not devices.
Thanks!
