Only one binary_sensor works at the time
I have a lot of sonoff light switches, and I only just noticed that only one binary sensor works at then same time. (my tasmota devices have the same behavior)
So when I press both switches together only 1 is triggered.
when I press 1 switch and hold it, this one is triggered
but the second one won’t be triggered unless I release the first one first.
but I want my switches to work independently, so I can press both at the same time.
my config looks like this:
esp8266:
  board: esp8285
  restore_from_flash: true
  early_pin_init: false
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      mode:
        input: true
        pullup: true
      inverted: true
    on_press:
      then:
        - switch.toggle: switch_1
  - platform: gpio
    pin:
      number: GPIO9
      mode:
        input: true
        pullup: true
      inverted: true
    on_press:
      then:
        - switch.toggle: switch_2
switch:
  - platform: gpio
    pin: GPIO12
    on_turn_on:
      then:
      - script.execute: set_status_led
    on_turn_off:
      then:
  - platform: gpio
    pin: GPIO5
    on_turn_on:
      then:
    on_turn_off:
      then:
light:
  - platform: status_led
    pin:
      number: GPIO13
      inverted: yes
script:
  - id: set_status_led
    then:
    - if:
        condition:
           or:
             - switch.is_on: switch_1
             - switch.is_on: switch_2
        then:
        - if:
            condition:
              - light.is_on: stat_led
            then:
            - light.turn_off: stat_led
            - delay: 200ms
        - light.turn_on: stat_led
        else:
    mode: restart
is this possible or is this some kind of limitation of the chipset?
