I did a migration, have been running HA from version 27.4 I guess never had I this kind of problems.
Now with core-2022.3.3 the latest newest I get this.
I went from a Raspi 3B to a Raspi 4 with SSD, Installed teh 64 bit version for I think soon that will happen to all, 32 bits is phased out slowly.
Everything worked, when it was a barebone HA installation nothing weird.
Then I tried to get in with samba that had stopped so I had to fix this.
put my migration backup from the old raspi 3 in the backup folder clicked restore … and all Hell broke lose.
CRITICAL (MainThread) [supervisor.jobs] The following job conditions are ignored and will make the system unstable when they occur: {<JobCondition.HEALTHY: ‘healthy’>}
WARNING (MainThread) [supervisor.core] System running in a unsupported environment!
Well I tried all the solutions given in de forum, none is working this is it, I am so dissapoitend and frankly super pissed cost me days and nothing works so, please please help me out to get this installation on the rails again, for now I revert to my good old raspi 3.
Are you trying to “apply” a backup from your 32bits system to your 64bits system ? ( im pretty sure that wont work) … what you could have done, is when after installing the 64bit system, configuring the “basics”, make a backup … just in case “something” happens
YAML-code should not be “prone” to “file-system”, but you should (just in case!) “copy/paste” any code/configs, from one to another
I chucked it all in the binn, fully erased the SSD, flashed it with Belena etcher this time.
And did a manual install of all addons and things, copied all esphome things from a normal backup I pulled, and so all the other things.
It still gave me some things i needed to think about but after a manual restore all is up and running again. pffffffh took me a day but
