Only show sensor value/atribute
Hi All,
This is probably a simple one but i just cannot find the answer as simpel as i need it.
i have a neocoolcam power socket, this al works (beside the bad range) but i like to start using them to read the power consumption.
but is want a single counter/sensor that tells me this sensor atribute value in the default cicle on the front page.
sensor details:
[switch.neo_coolcam_power_plug_12a_switch_2]
value_instance: 1
power_consumption: 369.15
value_id: 72057594126614528
node_id: 5
friendly_name: StudioMainPower
value_index: 0
i tried to add it in groups.yaml like this: (was hoping it was simple like this)
  • sensor.neo_coolcam_power_plug_12a_alarm_type_2.power_consumption
But this syntax is not allowed. So searched around and always end up on the template sensor page.
But i do not understand how to build a sensor like this. (if this is the way to do it, a simple example would be nice on that page, as i think this would be the first thing as beginner you would use it for)
Hope someone can help me out and give me some help/example.
Try sensor template
https://www.home-assistant.io/components/template/
Here is an example using your entities as you posted them above:
      sensors:
        power_consumption:
          friendly_name: 'Power Plug Power Consumption'
          entity_id: switch.neo_coolcam_power_plug_12a_switch_2
          value_template: '{{ states.switch.neo_coolcam_power_plug_12a_switch_2.attributes.power_consumption }}'
This worked like a charm. So i use Stats for this and with attribute i am selecting the attr of a sensor.
Got it thanks!
