Only use one of several fields: in script?
Hi!
I have recently started using scripts to streamline my automations. I have a script for when I need an automation to do notifications using notify and tts:
sequence:
  - parallel:
      - action: notify.notify
          message: "{{ message_notify }}"
      - action: media_player.turn_on
          entity_id: "{{ media_player }}"
        data: {}
      - action: media_player.volume_set
          volume_level: "{{ volume_level }}"
      - delay:
          hours: 0
          minutes: 0
          seconds: 1
          milliseconds: 0
      - action: tts.speak
          media_player_entity_id: "{{ media_player }}"
          cache: false
          message: "{{ message_tts }}"
          entity_id: tts.google_translate_sv_se
alias: TTS
description: ""
mode: parallel
fields:
  message_tts:
    selector:
      text: null
  message_notify:
    selector:
      text: null
  media_player:
    selector:
      entity:
        domain: media_player
        multiple: true
  volume_level:
    selector:
      number:
        min: 0
        max: 1
The script uses four different fields:, media_player (what entity that should play the TTS notification), message_tts (the message that should be read out using TTS), volume_level (settings the volume) and message_notify (the message that should be sent using notify).
I call the script like this in automations:
alias: Pelletsbrännare OK (dag)!
description: Announce when pellets burner is OK
triggers:
  - trigger: state
    entity_id: binary_sensor.vikingbio
    to: "off"
    for: "00:00:05"
conditions:
  - condition: state
    entity_id: input_boolean.natt
    state: "off"
actions:
  - parallel:
      - action: script.tts
          media_player: media_player.kok
          message_notify: Pelletsbrännaren OK! Klockan är {{ now().strftime('%H:%M') }}
          message_tts: Pelletsbrännaren OK!
      - action: scene.turn_on
          entity_id: scene.pellets_pre_alarm
        data: {}
mode: restart
initial_state: true
This works and let me for example change the model for tts.speak easily.
However! Sometimes I don’t want to use specific fields:. For example, sometimes I only want a TTS, not a text notification. If I leave out a specific field like message_notify the action is still executed but with an empty message.
Is it possible to make it so that if the field is missing in an automation, the script do not use the action?
I once looked at doing notifications this way but decided I was over complicating things for no benefit. I had to specify so many variables in my script call action that it was less work to just call the tts or notification action whenever i needed it rather than bothering with the script.
What’s the point of running a delay in parallel with all those actions…? I think you’re missing a sequence.
The easiest way is likely going to be templating the value for the actions’ enabled configuration variable based on whether the field variable has a value.
The next option would be to wrap every independent action or sequence in an If/Then action.
EDIT: I don’t know if it’s a bug or a Limited Templates thing, but I could not get the method of templating enabled to work in this situation.
Yes, you’re right. A sequence was missing. The notify and tts actions should be separated and running in parallell:
sequence:
  - parallel:
      - sequence:
            data: {}
          - delay:
              hours: 0
              minutes: 0
              seconds: 1
              milliseconds: 0
          - action: tts.speak
              cache: false
I’m not very good using templates. I tried using:
value_template: "{{ message_notify | default('') | trim != '' }}"
but this did not seem to work. I don’t know why?
Yeah, perhaps but if you have a bunch of automations using TTS and you want to switch voice it’s a hassle to change everything manually.
The default() filter won’t provide a value if the preceding value is undefined unless you set the second argument to true as follows:
value_template: "{{ message_notify | default('',true) | trim != '' }}"
But, I would just check that the variable is defined:
  - if:
      - condition: template
        value_template: "{{ message_notify is defined }}"
    then:
I have a script blueprint somewhere that checks if a field was passed in similar to what Drew did above, and if not it sees if there is an !input, and if not passes a default.
I’d have to search for it, but that’s the way I found to work that.
That was a much better solution than my attempt. For anyone trying something similiar, the script below now works as intended:
sequence:
  - parallel:
      - if:
        then:
      - if:
            value_template: "{{ message_tts is defined }}"
        then:
          - sequence:
              - action: tts.clear_cache
                metadata: {}
                data: {}
                data: {}
              - if:
                    value_template: "{{ volume_level is defined }}"
                then:
                    metadata: {}
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 5
                  milliseconds: 0
              - action: tts.speak
                  cache: false
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 15
                  milliseconds: 0
              - action: media_player.turn_off
                metadata: {}
                data: {}
alias: TTS
description: ""
mode: parallel
fields:
  message_tts:
    selector:
      text: null
  message_notify:
    selector:
      text: null
  volume_level:
    selector:
      text: null
  media_player:
    selector:
      entity:
        multiple: true
