Hello!
Need help with this issue on raspberry pi 4 with Home Assistant 0.104.0.dev20191214 version
With this setting camera work correctly, but need PTZ
- platform: ffmpeg
input: rtsp://admin:[email protected]:8001/
With this setting have error in log:
- platform: onvif
host: 192.168.1.54
username: admin
password: 653456w
port: 8001
log error:
2019-12-14 12:15:20 ERROR (MainThread) [homeassistant.components.camera] Error while setting up platform onvif
File "/usr/local/lib/python3.7/site-packages/onvif/client.py", line 26, in wrapped
return func(*args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/onvif/client.py", line 102, in __init__
transport = AsyncTransport(None) if no_cache else AsyncTransport(None, cache=SqliteCache())
File "/usr/local/lib/python3.7/site-packages/zeep/cache.py", line 80, in __init__
self._db_path = path if path else _get_default_cache_path()
File "/usr/local/lib/python3.7/site-packages/zeep/cache.py", line 160, in _get_default_cache_path
os.makedirs(path)
File "/usr/local/lib/python3.7/os.py", line 211, in makedirs
makedirs(head, exist_ok=exist_ok)
File "/usr/local/lib/python3.7/os.py", line 221, in makedirs
mkdir(name, mode)
PermissionError: [Errno 13] Permission denied: '/.cache'
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 150, in _async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
return fut.result()
File "/usr/src/homeassistant/homeassistant/components/onvif/camera.py", line 118, in async_setup_platform
await hass_camera.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/onvif/camera.py", line 166, in async_initialize
await self._camera.update_xaddrs()
File "/usr/local/lib/python3.7/site-packages/onvif/client.py", line 222, in update_xaddrs
self.devicemgmt = self.create_devicemgmt_service()
File "/usr/local/lib/python3.7/site-packages/onvif/client.py", line 334, in create_devicemgmt_service
return self.create_onvif_service('devicemgmt', from_template)
File "/usr/local/lib/python3.7/site-packages/onvif/client.py", line 322, in create_onvif_service
transport=self.transport)
File "/usr/local/lib/python3.7/site-packages/onvif/client.py", line 29, in wrapped
raise ONVIFError(err)
onvif.exceptions.ONVIFError: Unknown error: [Errno 13] Permission denied: '/.cache'
