I’m using an Amcrest IP2M-841B. The ONVIF integration works and I didn’t change anything in the ONVIF settings (FFMPEG settings are by default “-pred 1”). Now I have two problems:
a) the motion detection seems to be activated after some time (hours) from HA. I don’t want this motion detection, so I change this in the AmcrestViewPro app on my iPhone. Where is the place in HA to permanently disable motion detection on my ONVIF camera?
b) the Amcrest has PTZ but I can’t find an easy way to use it. There are of course some topics discussing PTZ but I need an example how to make the right configuration for this. Any idea?
Sorry cant help more i dont use it. But i see here that there is an option. I would try to add it manualy without installing integration if its possible? It should work and just skip the motion part.otherwise the integration doest have some settings file? I think you can open integration and just remove the sensor
Sorry for the delay. The motion detection was automatically activated again and again using the ONVIF integration. I don’t use the integration anymore and switched to the Amcrest solution. May be some day the ONVIF integration improves.
