ONVIF integration fail while it works on ffmpeg
With hass.io on rpi and latest 0.110.01 and HassOS 3.13 I have the following works:
camera:
  - platform: ffmpeg
    input: rtsp://[user]:[pass]@192.168.2.11:14896/profile1
now after reading the news on onvif on 110 release I tried to run the onvif integration from the integrations panel - it failed and on the log I saw this message:
Log Details (ERROR)
Logger: aiohttp.server
Source: components/onvif/config_flow.py:195
First occurred: 8:12:28 PM (1 occurrences)
Last logged: 8:12:28 PM
Error handling request
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
    resp = await task
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 39, in real_ip_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 73, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 125, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 145, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 54, in wrapper
    result = await method(view, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 103, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 153, in async_configure
    result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 201, in _async_handle_step
    result: Dict = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/onvif/config_flow.py", line 170, in async_step_auth
    return await self.async_step_profiles()
  File "/usr/src/homeassistant/homeassistant/components/onvif/config_flow.py", line 195, in async_step_profiles
    await device.update_xaddrs()
  File "/usr/local/lib/python3.7/site-packages/onvif/client.py", line 277, in update_xaddrs
    capabilities = await self.devicemgmt.GetCapabilities({"Category": "All"})
  File "/usr/local/lib/python3.7/site-packages/zeep/asyncio/bindings.py", line 13, in send
    options["address"], envelope, http_headers
  File "/usr/local/lib/python3.7/site-packages/zeep/asyncio/transport.py", line 107, in post_xml
    response = await self.post(address, message, headers)
  File "/usr/local/lib/python3.7/site-packages/zeep/asyncio/transport.py", line 95, in post
    proxy=self.proxy,
  File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 504, in _request
    await resp.start(conn)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/client_reqrep.py", line 847, in start
    message, payload = await self._protocol.read()  # type: ignore  # noqa
  File "/usr/local/lib/python3.7/site-packages/aiohttp/streams.py", line 591, in read
    await self._waiter
aiohttp.client_exceptions.ServerDisconnectedError: None
is this something I can fix?
thanks!
