I have an Onvis HS2 button, it is connected via Thread using the Homekit integration.
This HS2 has five programmable buttons. Each button is triggering an automation. This is how I’ve set the trigger:
alias: Play/Pauze muziek Praktijkruimte
description: Play/Pauze muziek Praktijkruimte
triggers:
- alias: Onvis HS2 - Knop 2 wordt ingedrukt
trigger: event
event_type: state_changed
enabled: true
event_data:
entity_id: event.onvis_hs2_fde927_stateless_programmable_switch_2
conditions: []
actions:
This works fine. However, since thread is a wireless protocol, on some occasions it gets disconnected. When reconnected, this automation is triggered as well. Which is very annoying when it happens.
How can I redefine the trigger, so it only triggers the automation when a button is actually pressed?
