Open a Dashboard on Amazon Alexa Echo Show
Congratulations on the work, incredible. Could you make this skill available in Brazil?
AMAZING! This is so cool!
How can I get back to the settigns? I entered full but still see the sidebar and the adress bar…
for option:
alexa ask ā€˜name skill’ setting
FOR OPEN SETTINGS LOOK FIRST POST… UPDATE…
if you have problems, disable and re-enable
Hi there all. I stumbled on to this skill searching for Alexa - yaml/html related discussions and found this one. Its exactly what i was trying to figure out!
I’m hoping its still active? I attempted to enable it on my Samsung S23 today and received this error. Any advice?
I did as it suggested but still receive the same. I also disabled, closed, force stopped and cleared the Alexa App and then reopened and attempted again. No luck :slightly_frowning_face:
And now i feel stupid. I read back thru and found this:
"42NetworkNathan Ellsworth
Jul 2024
Wow. I guess the Alexa list integration is broken as of today, July 1, 2024.
link
Warning: Starting July 1, 2024, you will no longer be able to use List skills or the List Management REST API to access Alexa lists, i.e., the Alexa Shopping and To-Do lists, in your skills or apps. For other ways to build custom voice experiences, see Steps to Build a Custom Skill. Please contact us if you have any questions."
this alexa skill is only for echo show. Not for other device
Alexa started saying ā€œerrorā€ today when I told her to ā€œopen home automationā€, tried disabling the skill and relaunching it, but that didn’t fix it.
I had the same issue - Amazon Show says ā€œerrorā€ and doesn’t launch the dashboard.
same issue here too.
@Bobsilvio the dashboard no longer opens, just says ā€œerrorā€ when opening it.
I’ve tried disabling and re-enabling the skill, no difference.
The same with me! Help!!!
Same for me. I hope there will be a fix.
@Bobsilvio
As well as the ā€œerrorā€ message when the dashboard starts, if you then ask Alexa to manually open silk, it responds with
ā€œYou requested Amazon fallback intentā€
To exit the failed dashboard you need to tell it to ā€œexitā€ or wait til it times out.
Seems to be working now.
Hi. The skill is not working at the moment. When i tell ALexa to open Home Assistant it says that it can’t reach the skill at the moment. Any fixing? Thanks
@Bobsilvio
the skill seems to be broken again, This time the error message is
sorry, I’m having trouble accessing your homeassistant dashboard skill right now
Same issue in here
