Open a port to a specific community AddOn's docker port
Hi all!
I’m using nightscout community module:
GitHub - marciogranzotto/addon-nightscout: Home Assistant Add-On for Nightscout
Within the docker container, there is a mongodb running.
I would like to open the mongodb port to the “outside” (i.e. being able to read the mongodb from my local laptop).
What is the best way to redirect a port to the nightscount-addon-docker mongodb port (27017) ?
Thanks a lot in advance for your help!
I believe, you need to fork the source repository and add whatever port you are interested in into add-on options and use your own fork locally. You should regularly fetch from upstream to keep up with changes and updates
