Open Garage Door Command Google Assistant
Hi Folks… Very new to Home Assistant… I have a relay setup to open up my garage door via the esphome addon. The only way google assistant will open the garage door is via command OK Google turn on garage door. Would someone point me in the right direction of how I go about switching the command to open garage door rather thank turn on garage door? Thanks
I have MyQ and Google linked. I need to add a PIN (or turn it off) to control without a blocker … It’s in as a cover device.
Can you redefine it as a cover instead of a switch? I think ESPHome supports defining a cover instead. Google will understand a “cover” properly and do the open/close thing.
Thanks I will look into it.
