I tried two different garage controllers and started having some strange connection issues with both of them after some time. Very short time. I tried Raspberry Pi Zero W and NodeMCU ESP8266. RPi Zero W started losing WiFi. NodeMCU connects/disconnect from my MQTT server that is on HA, but it does not lose WiFi connection.
I have two questions:
I mount my devices right above that motor that opens/closes the garage door. Is it possible that EM pulse is killing my devices?
Does anyone uses Open Source Garage Controller and can recommend me some? I have RPis and NodeMCU that I can use.
Signal is good inside garage. I also have RPi MotionEye camera and do not have any issues.
Not sure about the temp. It is the attached garage. It is obviously not like in the house.
I used the same outlet and the same power supply for both devices.
