Enjoy guys
BTW make sure you add “min_auth_mode: WPA2” (or WPA if your router doesnt support WPA2), or WPA3 to your YAML
Also make sure you replaced “Save\8 Heat” with “Save|8 Heat” in your YAML.
For reference check my updated YAML: esphome_gree_ac/examples/Gekkehenkie11.yaml at c85a60c720548233ebb47cda6e754d35ea7c136b · gekkehenkie11/esphome_gree_ac · GitHub
After that, you should not see any more warnings, let alone errors, related to any past or upcoming changes, all fixed now.
