Once again,Open the Marketplace and read the warning first, installing and updating work once it is accepted appears when installing any updates to HACS.
Did by any chance FBI/DHS/DOJ shut down HACS due to DMCA that happened to one app last year? If they did, then will there be a fork?
BRYCE M
And You Expect Anyone to Know WTH You are Talking about ?
Home Assistant Community Store is not showing anywhere and I go to install it it shows the following message.
BRYCE M
Could You please , in Order , describe what You did/want
As For HACS, install via the Apps Section, Then go to Integrations and Add it from there
Are you on Beta? Marketplace is Beta AFAIK.
I installed via apps section, installed via addon, restarted HAOS, and then cleared cache, went to the devices section and attempted to add it. not there
, i honestly haven’t heard about a MarketPlace
My apologies if I whiffed that Reply - I intended that for OP… I’ve only heard about Marketplace from a post on Reddit Frenck made earlier this week – I don’t know if it’s part of the new/current Beta (I’m not in Beta) or there just some code related to it that’s somehow snuck in.
Did *You by any chance, Started the HACS App(add-onn) before you restarted ?
Makes me curious ![]()
Marketplace is not found anywhere on my build.
FYI
Oh ok, thanks! Now marked as solved. Downgrading to 2026.9.4 due to this.
