Open URLs in same Tab
Hey all,
is it possible to open URLs in same Tabs?
The Situation: I linked to different Dashboards (Home Assistant and another one).
In my Home Assistant DB i added a Mushroom Chips card with an URL. But there is no possibility to tell the Chip card that the link should opened in the same Tab than Home Assistant.
Otherwise i will have a lot of Tabs after a while and i dont want to close that manually.
Is there any chance that i can just use one Tab for both Dashboards?
Thank you in advance.
BR
Use navigate on a relative URL ‘\dashboard\stuff’ , instead of URL with a a full URL.
It is an URL to an external side. With the target address i will leave Home Assistant. I think your solution just works when i link to another HA page.
@reppson:
Did you find a solution?
