Hi everyone,
I’m actually looking for a way to open a website when I press a button. I’ve been searching for a while now, but I’m not really finding anything. Can anyone point me in the right direction? Thanks in advance.
Hi everyone,
Use the url action.
Thanks for your response. Is it also possible that it’s triggered by an NFC tag?
tag_scanned is just an event type in a trigger. So, sure.
Thanks for your reply. Still, it’s not really working. To try, I simply try opening Google. I have the following configuration:
configuratie.yaml
rest_command:
google_command:
url: 'https://www.google.com/?hl=nl'
automatisering
description: ""
mode: single
triggers:
- trigger: state
entity_id:
- input_boolean.testknop_1
conditions: []
actions:
- action: rest_command.google_command
metadata: {}
data: {}
But I can’t really get it to work
This works and was your original question:
type: glance
entities:
- entity: sun.sun
tap_action:
action: url
url_path: https://google.com
Using the glance card as a button and a tap_action.
I don’t see where it works as an action in an automation.
Your last attempt is how you would do it to use a URL to do something. Send a command to a system that accepts commands from URLs. Not open a website.
But how do I do that with an NFC tag?
I am not seeing an action that can ‘just do it’ like that.
You can send a message to the device with a click action that opens the URL.
What I actually mean is, is it possible to scan an NFC tag and then open a specific website on my PC?
I completely understand. And I am telling you from what I have investigated answering your often changing question … the answer is … not directly that I can see. There may be work arounds.
I am tired. Maybe someone else will come along and help.
ok, thank you
Have a look at hass-agent.io
It can send commands to your pc to do all kinds of stuff, including open a webpage. Then just set up the automation in HA with the NFC tag as the trigger.
